Normally, Scene Composer should start via simply double-clicking the exe-file. On some PCs, however, it may be required to start the application with admin rights. So please right-click on the exe-file and then select “Run as administrator”.
This should fix the issue. If you still find yourself not being able to start the application please contact us in our Tool Support section.
